@ info-class, thank you. But there is no way to hide the logo I guess.
@background-image (in the back of graphs etc.). Here I was referring to my texquad that I mentioned at the beginning.
Did I miss an answer?
you said: Try setting the draw order of the quad to -1.
I said, this does not work because the Background is then behind my building.
Do I have to set all my objects (that have to be behind the quad) to object.draworder(-2)
Only because the sliders cannot be set to slider.draworder(1)
I can try a different approach.
Johannes
