Old 01-02-2011, 02:49 PM
You can add a function that's called every frame that checks the distance between the object and the center of the circle. Depending on the distance value you'll know whether the object is inside or outside of the circle:
import vizmat
CIRCLE_CENTER = [0,0,5]
CIRCLE_RADIUS = 2
court = viz.addChild('court.ive')
avatar = viz.addAvatar('vcc_male.cfg')
text = viz.addText('',parent=viz.SCREEN)
text.setPosition(0.3,0.8)
text.color(viz.RED)
walk = vizact.walkTo([0,0,10])
avatar.addAction(walk)
def collisionCheck():
	distance = vizmat.Distance(CIRCLE_CENTER,avatar.getPosition())
	if distance > CIRCLE_RADIUS:
		text.message('Outside circle')
		text.message('Inside circle')
vizact.ontimer(0,collisionCheck)
