Thread: data lose
Old 12-16-2010, 09:08 PM
psykoko psykoko is offline
attach my code
import vizmat
import vizinfo
import socket
import struct
viz.mouse.setVisible(viz.OFF)
#The maximum amount of data to receive at a time
MAX_DATA_SIZE = 1024
#The port to send/receive data on
PORT = 8000
#Get the name of this computer
COMPUTER_NAME = socket.gethostname()
#Get the IP address of this computer
COMPUTER_IP_ADDRESS = socket.gethostbyname('localhost')
#Create a socket to send data over
OutSocket = socket.socket(socket.AF_INET, socket.SOCK_DGRAM)
OutSocket.setsockopt(socket.SOL_SOCKET, socket.SO_REUSEADDR, 1)
#Create a socket to receive data from
InSocket = socket.socket(socket.AF_INET, socket.SOCK_DGRAM)
InSocket.setsockopt(socket.SOL_SOCKET, socket.SO_REUSEADDR, 1)
InSocket.bind(('', PORT))
InSocket.setblocking(0)
viz.directormode(viz.DIRECTOR_FAST)
def SendData(data):
	OutSocket.sendto(data,(COMPUTER_IP_ADDRESS,PORT))
def ReceiveData():
	try:
		return InSocket.recvfrom(MAX_DATA_SIZE)
	except:
		pass
def onkeydown(key):
	if key == ' ':
		#Send data over the socket
		SendData('hello there')
def ontimer(num):
	#Try to receive data from socket
	data = ReceiveData()
	if data:
		udp = struct.unpack(">d", data[0][:8])[0]
		right = open('c:\\new\\new.txt', 'a+')
		right.write(str(udp)+'\n')
		print 'Received Message:',udp
viz.callback(viz.TIMER_EVENT,ontimer)
viz.starttimer(0,0,viz.FOREVER)
