Old 11-10-2010, 07:57 PM
Here is a sample script showing how to draw a black line over the wireframe of a model:
viz.clearcolor(viz.GRAY)
frag_black = """
	void main()
	gl_FragColor = vec4(0,0,0,1);
shader_black = viz.addShader(frag=frag_black)
def addWireOutline(node):
	node.wire = model.clone(parent=node)
	node.wire.polyMode(viz.POLY_WIRE,op=viz.OP_OVERRIDE|viz.OP_ROOT)
	node.wire.zoffset(op=viz.OP_OVERRIDE|viz.OP_ROOT)
	node.wire.apply(shader_black,op=viz.OP_OVERRIDE|viz.OP_ROOT)
model = viz.addChild('ball.wrl',pos=(0,1.8,2))
addWireOutline(model)
model.addAction(vizact.spin(0,1,0,90))
vizact.onkeydown(' ',model.wire.visible,viz.TOGGLE)
Let me know if I misunderstood what you were asking for, or if anything is unclear.
