Thread: Co-ordinates
Old 10-25-2010, 01:00 PM
If you are using the powerwall example from the documentation there is an object caveorigin created from the CaveView class. You can use that to move the origin of the cave around within the virtual environment. You could set the position and orientation of caveorigin so that your model is directly in front when the script begins running.
