Old 10-22-2010, 10:19 AM
kopper kopper is offline
Thanks, Masaki, for your reply.
I used the code you sent and it indeed worked to have the HUD to display correctly in the HMD.
However, when I try to add an image, instead of a text to the hud, it does not display, if I set parent to viz.ORTHO. The way I have it working in mono is the following:
	crosshair = viz.addTexQuad(viz.SCREEN,texture=viz.add('crosshair.png'))
	crosshair.setPosition([0.5,0.5,0])
When I try to add the image with viz.ORTHO as parent, like this:
	crosshair = viz.addTexQuad(viz.ORTHO,texture=viz.add('crosshair.png'))
	w = int(viz.getOption('viz.monitor.width'))
	h = int(viz.getOption('viz.monitor.height'))
	crosshair.setPosition([0.5*w,0.5*h,0])
nothing shows on the screen.
Could you point me how I can do the equivalent to the example you sent before, but with an image, instead of text?
Thanks a lot!
Regis
