Old 10-18-2010, 08:47 AM
just alex just alex is offline
Sorry, i had a case of the dumb and posted an old code I was messing with. This should all be with general stuff so you shouldn't need to make any alterations. All I really need is for the avatars to walk around continuously to create a little veracity in my city.
import math
import vizmat
import vizinfo
#Add the street and drop it a little bit to be below the avatars feet.
street = viz.add('tut_ground.wrl')
street.translate(0,-.2,0)
females = []
walking = []
whichturn = 0
#List the timers.
WALKING = 0
HOLDVIEW = 8
TIMING = 9
for i in range(1):
	female = viz.add('vcc_female.cfg')
	female.translate(i,0,0)
	females.append(female)
#Set up paramters for walking girl.
females[0].translate(1,0,-7)
females[0].rotate(0,1,0,-90)
females[0].whichturn = 0
females[0].set = [[1.5,0,0],[1,0,15],[2,0,15],[-5,0,-5]]
females[0].end = 3
walking.append(females[0])
#Add car.
car = viz.add('mini.osgx')
#set car stuff
car.translate(-1.5,0,8)
car.rotate(0,1,0,180)
#Set up for timing.
timebomb = 0
def onkeydown(key):
	if key == '0':
		viz.starttimer(WALKING, .1, viz.PERPETUAL)
def ontimer(num):
	global gravity, timebomb
	if num == WALKING:
		for agent in walking:
			agentposition = agent.get(viz.POSITION)
			agentgap = vizmat.Distance(agentposition, agent.set[agent.whichturn])
			if agentgap < .1:
				agent.whichturn += 1
				if agent.whichturn == agent.end:
					agent.whichturn = 0
			walk = vizact.walkto(agent.set[agent.whichturn][0],agent.set[agent.whichturn][1],agent.set[agent.whichturn][2])
			agent.addAction(walk)
	if num == HOLDVIEW:
		view.translate(-8.5,1.5,-2)
	if num == TIMING:
		print timebomb
		timebomb += 1
		if timebomb == 1:
			onkeydown('0')
		elif timebomb == 3:
			onkeydown('8')
		elif timebomb == 10:
			onkeydown('9')
		elif timebomb == 20:
			onkeydown('3')
		elif timebomb == 30:
			onkeydown('1')
		elif timebomb == 80:
			viz.quit()
viz.callback(viz.KEYDOWN_EVENT,onkeydown)
viz.starttimer(HOLDVIEW,.001, viz.PERPETUAL)
