Old 10-17-2010, 01:37 AM
dwaik dwaik is offline
Exclamation
when publishing exe, vizard only gather the assests loaded at the beginning of the the application, other dynamically loaded (ex on event x viz.add(y)) you must specify them by adding them while publishing, drag the textures and drop them into the list which appears at step 2 of publishing
hope that helps
