Old 09-30-2010, 11:12 AM
codexter codexter is offline
Decreasing PPT Jitter
At the moment, there is degree of jitter in our PPT light that is being tracked by an 8 camera system. The light is clearly being seen by all 8 cameras (thanks to the Camera Visualization Plugin) and all cameras are successfully calibrated to the right levels. I'm familiar with the Filter post-process plugin through PPT Studio, and here are the settings I used to eliminate the jitter:
PosRate:5%
OriRate: 5%
PosCutoff: 1000mm
OriCutoff: 90deg
However, by implementing these values in the Filter it creates a 1-second lag time in Vizard where after the light moves and the rendered world takes a moment to catch up (disorientating). Any ideas on how to decrease jitter but keep lag at a minimum? Our tracking code in all programs is the standard:
import viztracker
viztracker.go()
Is there a way to implement a filter on the client side through the viztracker.py to decrease lag?
Thanks for the help.
Cody Karutz
Stanford VHIL Lab
