Old 09-27-2010, 12:14 PM
The second dialog in the publish wizard contains a checkbox labelled Display console. You can use this option to display an output console for your published exe.
If you prefer to log the ouput to a file, then you can use the viz.setLogFile command to redirect all output to a file. You will probably want to specify an absolute path if using this command with a published exe.
