Old 09-23-2010, 06:09 AM
kay kay is offline
hi,
i tried to find a reproducible example. The maximum recursion depth error doesn't appear allways. Often everything work smoothly now.
However ... use either the intialPos inside the tunnel and go to the outside and collide with it or use the outside initialPos and collide with the inside of the tunnel in the example below. The error should appear then.
ob=viz.add('playground.wrl')
ob.setScale(1.5,1.5,1.5)
#initialPos=[14.,0.75,13.5]  # inside tunnel
initialPos=[6.,0.75,13.5]    # outside tunnel
viz.MainView.setPosition(initialPos)
viz.MainView.eyeheight(initialPos[1])
viz.collision(viz.ON)
print viz.MainView.getPosition()
def onCollision(info):
    print "collision at ", info.point
viz.callback(viz.COLLISION_EVENT,onCollision)
By the way, here is the full error, maybe this helps to understand what's happening:
File "<string>", line 0, in ?
File "C:\Program Files (x86)\WorldViz\Vizard30/python\viz.py", line 367, in __init__
self.object = _GetNode(data[7])
RuntimeError: maximum recursion depth exceeded
