Thanks for the post. This problem will be fixed in the next release.  If you need to get screenshots right away, I would recommend using a free tool called FRAPS.  You can download it at
www.fraps.com.  This tool allows you to create screenshots and movies from any OpenGL window.  Just download and install the program.  When you run it click on "Enable screen capture" and disable the option "Include framerate on screen captures".  The screenshots will be saved to the Fraps directory.
-- Farshid
