Old 01-17-2005, 01:05 PM
tobin tobin is offline
You can apply an offset to the PPT tracking data. Look here for how to use command 7:
http://www.worldviz.com/vizhelp/VizH...er_plug-in.htm
What you'd want to do is reset your tracker, read the user's actual height, calculate the difference between his/her height and your desired virtual height, and then apply that difference as an offset.
