Old 09-03-2010, 02:03 PM
When you scale the bar it's center will remain in the same position. You could either change the bar's center to be at the end that will touch the wall or re-position the bar after scaling it. The following code moves an object's center so it will stay aligned with the ground when scaled:
box = viz.add('box.wrl',pos=[0,0.5,0],scale=[0.2,1,0.2])
box.center(0,-0.5,0)
vizact.onkeydown('1',box.setScale,0.2,1,0.2)
vizact.onkeydown('2',box.setScale,0.2,1.5,.2)
vizact.onkeydown('3',box.setScale,0.2,2,0.2)
vizact.onkeydown('4',box.setScale,0.2,2.5,0.2)
import vizcam
viz.cam.setHandler(vizcam.PivotNavigate(center=[0,1,0],distance=6))
