environment maps, scenes, and you!
so i want to make an experiment where i change the scenes (each with a different environment map). the code i have from the examples is:
env_map = viz.add(viz.ENVIRONMENT_MAP,'Terrain.png')
sky = viz.add('skydome.dlc')
sky.texture(env_map)
however, this only adds the terrain to the first scene. i have tried
env_map = viz.add(viz.ENVIRONMENT_MAP,'Terrain.png', viz.WORLD, scene)
and
sky = viz.add('skydome.dlc', scene)
and
sky = viz.add('skydome.dlc', viz.WORLD, scene)
but the code either throws an error, or it doesn't change anything.
