Old 01-11-2005, 04:42 PM
Johannes Johannes is offline
Changed it and got the following exception: pointliste [[0.6171875, 0.60208332538604736], [0.7421875, 0.42916667461395264], [0.29843750596046448, 0.55833333730697632], [0.48906248807907104, 0.54583334922790527], [0.74531251192092896, 0.44374999403953552]]
File "050110_DrawPointProblem_forum.py", line 99, in mousedown
drawPoints()
File "050110_DrawPointProblem_forum.py", line 137, in drawPoints
viz.vertex(object)
File "C:\Program Files\Vizard25\viz.py", line 3692, in vertex
_ipcSend(_VIZ_VERTEX,0,0,'',x[0],x[1],x[2],0)
IndexError: list index out of range
RADIUS=1
viz.startlayer(viz.LINE_LOOP)
viz.vertexcolor(2, 4, 4)
viz.vertex(-RADIUS, -RADIUS, RADIUS)
viz.vertex(-RADIUS,  RADIUS, RADIUS)
line = viz.endlayer()
viz.vertex(RADIUS,  -RADIUS, RADIUS)
line2 = viz.endlayer()
#line.translate(3,2,4)
SPIsSet,EPIsSet=0,0
startPoint=[0,0]
show=1
pointListe=[]
def mousedown(button):
		global startPoint,SPIsSet
		global endPoint,EPIsSet, pointListe
		if SPIsSet==0:
			startPoint=viz.mousepos()
			#print 'startPoint:',startPoint
			#SPIsSet=1
			pointListe.append(startPoint)
			drawPoints()
			print 'forgot option 3'
	if button == viz.MOUSEBUTTON_RIGHT:
		show=1
		drawPoints()
def drawPoints():
	viz.startlayer(viz.POINTS)
	viz.vertexcolor(0,12,1)
	viz.pointsize(2)
	for object in pointListe:
		print 'pointliste',pointListe
		viz.vertex(object)
	points = viz.endlayer(viz.SCREEN)
