I'd like to send the character changed in MotionBuilder to the real time in vizard using LiveCharacter.
http://kb.worldviz.com/articles/160
I want to send a sample in LiveCharacter to vizard like this animation, but an error is reflected on vizard and fails even if I operate it in the same way as an animation.
An error is as follows:
	** WARNING: LiveCharacter has not received response from server at address localhost:8050
 An IP address and the port number are displayed in a Clients column of MotionBuilder side then, but there is not reaction in vizard side.
How should I do?
Thanks for your help.
viz.add('tut_ground.wrl')
import vizmocap
avatar = viz.add('vcc_male.cfg',pos = [0,0,5], euler = [180,0,0])
lc1 = vizmocap.LiveCharacter('localhost',8050,model=avatar)
