comparing data between 2 continous frame and stereo vision
First question
I made a head track and compared vision system, but I have some problems because of noise.
So, I want to make a filter to decrease the noise.
The filter system which I am thinking about is following. I want to campare head's angle data in continuos 2 frames.
1. compare head's angle data in current frame and 1 frame before.
2. if change of value > x, the data in current frame will be ignored.
following is some part of my code
[CODE]def mytimer(num):
data = body.getPosition()
euldata = body.getEuler()
if abs(pre1 - euldata[0] + pre2 - euldata[1] + pre3 - euldata[2])<100:
view.translate(data[0],data[1]+1,data[2])
view.rotate(euldata[0],euldata[1],euldata[2])
pre1 = euldata[0]
pre2 = euldata[1]
pre3 = euldata[2]
viz.starttimer(0,0,viz.FOREVER)[\CODE]
There is error that 'can't use data of frame before'.
How can I do it??
Second question
I want to see stereo vision in HMD, but I can't.
2 monitors of HMD should show each vision, but they should not.
2 monitors show two stereo visions like in 1 monitor.
I don't know what is the problem.
I am using quadro fx 1400 and HMD - i-visor fx601.
setting is : stereo - enable, stereo mode - shutter glasses use
following is my code
[CODE]
viz.setOption('viz.fullscreen.monitor',2)
viz.go(viz.QUAD_BUFFER|viz.STEREO|viz.HMD|viz.FULL SCREEN)
viz.add('court.ive')
viz.collision(viz.ON)
class CameraControler(viz.CameraHandler):
def _camUpdate(self,e):
if viz.iskeydown(viz.KEY_UP):
e.view.move(0,0,e.elapsed*5)
elif viz.iskeydown(viz.KEY_DOWN)
viz.cam.setHandler(CameraControler())
[\CODE]
