Old 07-26-2010, 10:32 PM
znchb znchb is offline
thank you for your reply, I copy the file to here.
viz.add('tut_ground.wrl')
viz.clearcolor(viz.GRAY)
view = viz.MainView
PORT_INTERSENSE = 1
sensor = viz.add('intersense.dls')
viz.tracker()
link = viz.link( sensor, view )#this link the Sensor's Orientation with View
#vrpn = viz.add('vrpn7.dle')
#tracker1 = vrpn.addTracker('Tracker0@localhost')
#tracker2 = vrpn.addTracker('Tracker0@localhost',1)
def onTimer(num):# try to control the MainView's position, by getPosition #from sensor, however, it doesn't work
pos = sensor.getPosition()
euler = sensor.getEuler()
print pos
print euler
view.setPosition(pos)
view.setEuler(euler)
