Old 01-10-2005, 05:51 PM
Can you try out the following sample script. It is a really simple script that has a ball bouncing around the room you are using. The calculations are done inside a director function. Let me know if this works for you.
import vizmat
myroom = viz.add('room.wrl')
ball = viz.add('ball.wrl')
myroom.collidemesh()
ball.collidesphere(0.25)
ball.vector = viz.Vector(1,1,1)
ball.translate(0,1,0)
def moveball():
	while 1:
		#Perform the collision check with the room
		info = ball.collidingwith(myroom,1)
		if info.intersected:
			#Set the balls new vector to the reflection vector
			ball.vector = viz.Vector(vizmat.ReflectionVector(ball.vector,info.normalVector))
			#Create a vector of the normal of the collision
			normal = viz.Vector(info.normalVector)
			#Check dot product of velocity and normal
			if ball.vector * normal < 0:
				ball.vector *= -1
		#Get the balls current position
		pos = ball.get(viz.POSITION)
		#Calculate the balls future position based on its velocity
		futurePos = pos + (ball.vector * 0.02)
		ball.translate(futurePos.get())
		viz.waittime(0.01)
viz.director(moveball)
