A. collidemesh tells vizard that all collision tests with the object should be performed with the underlying geometry mesh. What kind of object is myroom? Are you getting any error messages? Is the ball actually intersecting with the room mesh when your code is called? Are you executing the code inside a director function? If so, have you tried executing it elsewhere, like in timer or keyboard callback? Sorry for all the dumb questions, but I just want to make sure I know excactly what is going on.
B. Yes, info.normalVector returns the normal of the collision surface.
C. No, Vizard doesn't currently have this command.
