Old 01-10-2005, 04:59 PM
Johannes Johannes is offline
A. The ball and the room are the only ones but soon there will be more objects then I will need it anyway.
So if my room is called myroom and my ball is called ball why does this not work?
This is the important part:
collidables=[]
myroom.collidemesh()
collidables.append(myroom)
ball.collidesphere(0.25)
collidables.append(ball)
and in then in the move function I checked:
for objects in collidables:
#Perform the collision check with the object
info = ball.collidingwith(object,1)
if info.intersected:
Could the reason be, that myroom does not have a 'collidemesh'? This is basically my first question - how can I find out, which properties objects posess?
B. Does info.normalVector give me the Normal to the object-surface the ball hit?
C. Is there a function to do a complete stop and restart of the program by typing a certain key (it must basically be the same as typing the run-button in your program) e.g.
def mykeyboard(key):
if key == 'r':
viz.resetProgram()
Johannes
