Thread: Move Objects
Old 01-06-2005, 12:12 PM
Are you executing your moveIt2 function as a director function? If not then your function will stall the graphics frame until it is finished. To execute your code as a director function do the following:
viz.director(moveIt2)
This will execute your function asynchronously. Whenever you call the sleep command outside of a director function or thread you are effectively causing the graphics loop to sleep also.
