Old 05-24-2010, 12:48 PM
I'm not sure what's wrong without seeing more of the script. In the following example viz.COLLIDE_NOTIFY is enabled on the ball. When the ball collides with another object it will generate the collision event and show up as obj1 in the callback function. The object it collides with will be obj2.
viz.phys.enable()
ground.collidePlane()
ball = viz.add('ball.wrl',pos=(0,1.8,6))
ballPhys = ball.collideSphere(bounce=1.5)
ball.enable(viz.COLLIDE_NOTIFY)
def onCollide(e):
	if e.obj1 == ball:
		print 'ball collision'
	if e.obj2 == ground:
		print 'ground collision'
viz.callback( viz.COLLIDE_BEGIN_EVENT, onCollide )
