Old 09-09-2003, 11:10 AM
keastman keastman is offline
movement problems
I'm working with bstankie's PPT system, and sometimes when I start a session, the movement seems to be off by 5-70 degrees, meaning, when I move my body forward, I move left or right in the environment. How do I fix this?
Kyler Eastman
Old 09-09-2003, 11:41 AM
mspusch mspusch is offline
Hi Kyler, when starting the Vizard script or resetting the InertiaCube2 direction the heading direction of the HMD/IC2 setup must be towards virtual north. If that's not the case, your movement direction will be off by the degree of your initial offset to the virtual north.
Hope that helps! Matthias
