Old 03-24-2003, 08:30 PM
mdebrecht mdebrecht is offline
Smile <viewpoint>.setclip
I like the new interface to VRUT. Good Job! I just have a few quick questions:
It seems that when I try to clip a seperate viewpoint, the whole screen goes black. Similar code works for vrut, but doesn't seem to work with viz. Do you know what may be going wrong?
viz.add('Layout.wrl')
window = viz.addwindow()
window.setposition(0, 380)
window.setsize(100, 100)
view = viz.addviewpoint()
window.setviewpoint(view)
view.setclip(0,40)
Also, I noticed that Tkinter isn't included in viz's built-in python library. Do you know of a good way to import Tkinter?
Matthew
Old 03-25-2003, 01:13 PM
Hi Matthew,
Instead of setting the clip at (0,40) try something like (0.01,40).
We'll try to fix this, but for now this should work.
As for Tkinter, it doesn't come with Vizard, but you should be able to download and install it separately. I'll try this out and get back to you on it.
-- farshid
Old 03-27-2003, 01:30 PM
thanks for your reply. I already have Tkinter installed with Python; is there anyway to tell Vizard which directories to search when importing a module?
Old 03-27-2003, 01:54 PM
Hi Matthew,
You have two options:
1) Place all the Tkinter files in the Vizard/bin/lib directory
2) At the beginning of your script before you import tkinter issue the following command:
import sys
sys.path.append(<path to tkinter library>)
Hope that works!
-- farshid
