Old 03-22-2007, 10:40 PM
m7ossny m7ossny is offline
Question How to access scene information in a C++ modifier
I am building a new C++ modifier for Vizard. I am intending to handle the whole scen at once.
modifier=viz.add('modifier.dlm')
logo1=viz.add('logo1.wrl')
logo2=viz.add('logo2.wrl')
viz.modify(modifier)
Well, the last command calls a native code in the dlm file in the function named "void SceneModifier(void *modifier)"
In this function i can get the whole scene through the modifier parameter.
VizModifierObj* pscenemodifier=(VizModifierObj*)modifier;
osg::Node* pnode=pscenemodifier->node.get();
The question is how to get seperate nodes declared in this scene?
Thanks alot for time, Bye.
Old 03-23-2007, 11:02 AM
To get the root of each individual vizard node, you will need to create an osg::NodeVisitor that traverses the scenegraph and checks the user data of each node. Here is some sample code that will do this:
class VizNodeData : public osg::Referenced
public:
	VizNodeData(int id) : m_id(id) {}
	int getID() const { return m_id; }
private:
	int m_id;
class VizardNodeVisitor : public osg::NodeVisitor
public :
	VizardNodeVisitor() : osg::NodeVisitor( TRAVERSE_ALL_CHILDREN ) {}
	virtual void apply( osg::Node &node )
		VizNodeData *data = dynamic_cast<VizNodeData*>(node.getUserData());
		if(data) {
			//This is the root of a Vizard node with ID: data->getID()
		traverse(node);
Then in your SceneModifier function you will need to apply this node visitor to the scene root:
VizardNodeVisitor vnv;
((VizModifierObj*)modifier)->node->accept(vnv);
Let me know if you need anymore help.
Thread Tools
Rate This Thread:
