How to pick objects with joystick?
Hi all,
I am trying to use the joystick to navigate, however i am not able to pick objects with it as I am with the mouse, as here: def pickChair(): object = viz.pick() if object==chair1 or object==chair2: if object.valid(): object.visible(viz.OFF) vizact.onkeydown(' ', pickChair) Does anyone know how to do this, but using the joystick? Thank you in advance. Best regards, Isabel |
Picking works with the mouse but you could simulate mouse movements with the joystick and use picking or you could use joystick data in combination with the screenToWorld and viz.intersect commands to select an object. How do you want to control the pointer since you're navigating with the joystick?
Similar Threads | ||||
Semi-circle array containing target and distractor objects | ptjt255 | Vizard | 3 | 08-04-2009 03:09 AM |
writing joystick position to a data file | Saz | Vizard | 3 | 12-17-2008 05:18 AM |
Pick porblem with arrays | shivanangel | Vizard | 3 | 08-27-2007 10:10 AM |
Could not find plugin to load objects... | halley | Vizard | 1 | 05-30-2006 11:01 AM |
Facetracking and Immersion Joystick | Vygreif | Vizard | 1 | 01-25-2006 10:56 AM |
