Old 06-15-2018, 04:43 AM
harshad harshad is offline
Registered User
Polhemus Fastrak Vizard
polhemus = viz.add('polhemus.dle')
sensor = polhemus.addFastrak()
data = sensor.getData()
print(data)
getData() function returns empty list.
I wish to interact with a virtual environment made in Vizard. I am using polhemus fastrak. Please provide step by step guide to interface sensor with vizard.
Old 06-17-2018, 04:08 PM
See the notes on the Polhemus page regarding the fastrak connection. In order for Vizard to connect to the sensors, PiMgr should not be running. The following code will print out the data each frame once a connection is made.
def printData():
	pos = sensor.getPosition()
	ori = sensor.getEuler()
	print 'pos',pos
	print 'ori',ori
vizact.onupdate(0,printData)
Also, take a look at vizconnect for setting up up a configuration file that connects to the sensor.
Old 06-19-2018, 02:11 AM
Registered User
thank you!
I am facing one more issue. Vizard movements are not the same as my movement along x,y,z in physical world. Is there some calibration required. How do I do it?
Polhemus FasTrak Error Message JB_HP_Viz Vizard 4 08-15-2014 09:32 AM
Polhemus Fastrak williamchappell Vizard 11 09-28-2013 08:49 AM
