Old 03-20-2010, 07:19 AM
Josh Josh is offline
<node>.unlink will be deprecated in future versions of Vizard?!
Hi all
I added the following code from the help tutorial to my script:
morphing_face = avatar.face('male.vzf')
Now I'm getting the following message:
** WARNING: <node>.unlink will be deprecated in future versions of Vizard, use viz.link instead
What should I do?
Josh
Old 03-22-2010, 10:36 AM
Somewhere in the code a <node>.unlink method is called which should be replaced with viz.link.
link = viz.link(hand,ball)
link.remove()
Old 03-22-2010, 10:46 AM
That warning message is a mistake and will be fixed in the next release. You can just ignore it.
.3DS importing in Vizard and 3D Studio jde Vizard 1 08-28-2009 03:14 PM
McAfee Privacy Service 8.1 causes Vizard not to run mspusch Vizard 0 03-01-2007 08:24 PM
