Old 06-01-2009, 09:22 PM
Brett Lindberg Brett Lindberg is offline
Wide-angle view
Is there a smooth way in Vizard to generate a wide view FOV (say, greater than 180 degrees?)
I'm trying to "unwrap" a spherical panoramic view into a quad, but I can't get it right: if I set FOV greater than 90, it messes everything up. I've tried to get around this by compositing four 90-degree views, but there is significant distortion at the boundaries.
What I'd like is a wide, short view (say 4:1, across the top of the window), rendering the a 360 panorama of same scene as the normal main view.
Old 06-11-2009, 12:30 PM
Have you gotten any further with this? I'll check with our dev team to see if they have some suggestions.
Old 07-15-2009, 01:13 PM
Haven't gotten it to work yet: trying to make a bunch of very narrow views stuck close together, but this isn't that great a solution, because I want to be able to get coordinates.
Old 07-15-2009, 05:31 PM
You need to render multiple views to a texture and then render the textures to the screen using either an undistortion mesh or shader. There should be examples on the forum for rendering views to a texture.
Old 08-20-2009, 09:05 PM
I hacked my way around and came up with this: draws 40 windows across the top of the window. I could render to texture, and make one window, but would that be a lot better?
import math
class PanoWindowGroup:
	def __init__(self, SubWins=40, windowHeight=0.3, vertFOV=90):
		self.numSubWins = SubWins
		self.winHeight = windowHeight
		self.winFOV = 360.0/self.numSubWins
		self.vFOV=vertFOV
		self.sizeRat = 1.0/self.numSubWins
		self.size = (self.sizeRat, self.winHeight)
		self.subWinArr = []
#experimentally derived sub-window FOV ratio:
#		self.subWinFOVrat =  4.3015/(pow(self.numSubWins,1.113))
		for i in range(self.numSubWins):
			scrPos = ((i*self.sizeRat),1.0)
			direction = i*self.winFOV-60.0
			print "Direction= ", direction
			subWin = PanoSubWindow(scrPos, self.size, direction, self.winFOV, self.vFOV, self.subWinFOVrat )
			self.subWinArr.append(subWin)
class PanoSubWindow:
	def __init__(self, scrPos, sizer, direction, winFOV, vFOV, sWFR, viewPos=[0,0,0]):
		print "Inputs: ", "scrPos= ", scrPos, " sizer= ", sizer, "direction= ",direction, "winFOV= ", winFOV, "vFOV= ", vFOV
		self.vFOV = vFOV
		self.size = sizer
		self.subwindow = viz.addWindow(pos=scrPos, size=sizer)
		self.subwindow.visible(0, viz.SCREEN)
		self.subWinFOVrat = sWFR
		self.subview = viz.addView()
		self.subview.setPosition(viewPos)
		self.subview.setEuler([direction,0,0])
		self.subwindow.setView(self.subview)
#		self.subwindow.fov(self.vFOV, self.subWinFOVrat)
		self.subwindow.fov(self.vFOV, 0.075)
Old 08-29-2009, 01:14 PM
Take 3: how do I render multiple views to one texture?
There's only one example on the forums: http://forum.worldviz.com/showthread.php?t=2003, but that's only for one view.
Old 09-03-2009, 06:05 PM
For each view, you would create a separate render node and render texture. You would then apply all the render textures from each view to a separate texture unit of a quad. Finally, you would apply a fragment shader on the quad that performs the undistortion using the different textures. I can provide some sample code that sets this up if you like, but you would still need to come up with your own shader code that performs the undistortion.
Old 09-03-2009, 07:25 PM
A sample to get started would be great: the shader stuff should be doable.
Old 09-04-2009, 04:57 PM
Here is a sample script. The shader simply averages the image from each pass, you will need to replace that with your own shader code.
FRAG = """
uniform sampler2D Pass1;
uniform sampler2D Pass2;
uniform sampler2D Pass3;
uniform sampler2D Pass4;
void main()
	vec4 p1 = texture2D(Pass1, gl_TexCoord[0].xy);
	vec4 p2 = texture2D(Pass2, gl_TexCoord[0].xy);
	vec4 p3 = texture2D(Pass3, gl_TexCoord[0].xy);
	vec4 p4 = texture2D(Pass4, gl_TexCoord[0].xy);
	//TODO: Combine texture from each pass
	gl_FragColor = (p1+p2+p3+p4) * 0.25;
def CreateRenderPasses():
	renderPass = []
	uniforms = []
	#Create post render pass that combines all passes
	postRenderPass = viz.addRenderNode()
	postRenderPass.setHUD(-1,1,-1,1,renderQuad=True)
	postRenderPass.setOrder(viz.POST_RENDER,-1)
	#Create each pass
	for x in range(4):
		#Create render texture
		renderTexture = viz.addRenderTexture()
		#Apply to post render pass
		postRenderPass.texture(renderTexture,unit=x)
		#Create uniform for texture unit
		uniforms.append(viz.addUniformInt('Pass'+str(x+1),x))
		#Create render node to render texture
		renderNode = viz.addRenderNode()
		renderNode.attachTexture(renderTexture)
		renderPass.append(renderNode)
	#Apply shader
	shader = viz.addShader(frag=FRAG,uniforms=uniforms)
	postRenderPass.apply(shader)
	#Set rotation offset of each render pass
	renderPass[0].setEuler(-30,0,0)
	renderPass[1].setEuler(-10,0,0)
	renderPass[2].setEuler(10,0,0)
	renderPass[3].setEuler(30,0,0)
viz.add('gallery.ive')
View nlfrnassimi Vizard 0 03-17-2009 02:01 AM
View nlfrnassimi Vizard 4 03-12-2009 05:25 AM
problem with stereo mode shivanangel Vizard 3 10-17-2006 09:58 AM
keeping a 3d object in front of the view tavaksai Vizard 1 07-07-2004 09:33 AM
SEOS HMD 120/67 compatability John Vizard 18 05-28-2004 11:13 AM
