Old 01-12-2009, 10:41 AM
vNicolef vNicolef is offline
Problem with the HMD Right Lens
Hi there,
I have an NVisor SX HMD and while using it one day, the right lens all of a sudden stopped working and only displayed black and white vertical lines. I turned it off and made sure all the connections were tight and even rebooted the system, but it still only shows the black and white vertical lines. So I turned it off for several hours and now instead of black and white vertical lines, it's displaying black and white dots all over the screen. It looks like static but it's not moving r changing, it's just stationary. Is there anything I can do to try and fix this problem?
Old 01-12-2009, 02:34 PM
mspusch mspusch is offline
the easiest way to diagnose this is to connect a monitor to both VGA channels which you are feeding inth the nVisor SX. if the resolution on both monitors is 1024x1280 and the frequency 60Hz, then it's pretty sure that this is a nVis hardware issue and you need to contact nVis about it.
http://www.nvisinc.com/
Vertex shader performance problem Joran Vizard 2 11-17-2008 01:29 AM
5DT Data Glove 5 Ultra Problem bjgold Vizard 1 08-08-2006 04:08 PM
sound problem alaa Vizard 7 09-02-2005 01:13 PM
PROBLEM: Picture-in-Picture breaks textures?!? vcarlson Vizard 4 10-05-2004 04:22 PM
