Old 05-14-2021, 09:14 AM
anon8hi anon8hi is offline
Angry steamvr movement speed
Hey,
I am working with the HTC Vive (steamvr) and trying to increase the speed of movement. In my project there is no avatar for the user, the movement increase should refer to the glasses (the MainView should do like 3 steps instead of 1).
I have already tried to embed several config files, but there was no effect. Also the values 'acceleration' and 'maxSpeed' were adjusted.
In the tracker code I have created a 'head_tracker' and then linked it in the transport code (main_transport).
Reason for this whole thing: the room is too small, so the user should do 2-3 steps instead of 1.
I would be very grateful if you could take a look at my config file. Maybe some embedding/linking to the tracker/MainView is wrong, I've no clue.
With kind regards,
anon8hi
Old 05-15-2021, 06:50 AM
looks like the following code is moding the movement speed, but this has no impact in my VR scene. If I try to modify it via vizconnect tool, I see the impact in the test scene, but afterwards in my enviroment, it has no impact on the movement speed.
It feels like: something is overwriting it
#VC: apply offsets
_link.postScale([4, 1, 3])
Old 08-25-2021, 09:42 AM
sado_rabaudi sado_rabaudi is offline
You could try using .setParent to link the transport to the head. Is there a reason you don't want to add the SteamVR tracker in vizconnect and link that to your mainview? Then you could just drag the SteamVR tracker under the transport. The acceleration is controlled by the transport.
Best,
Sado
acceleration, configuration, movement, steamvr, vizconnect
Check for running SteamVR A Wundlechner Vizard 2 01-11-2018 01:03 AM
stop speed movement and allow rotating only while using vizconnect bbb Vizard 1 02-29-2016 06:32 AM
Inconsisten movement speed of the viewport mape2k Vizard 9 07-24-2013 12:02 AM
random speed and associated coding Saz Vizard 1 05-20-2010 04:03 AM
Calculating Speed with sensor durf Vizard 1 03-13-2009 10:25 AM
