Making avatar point with hand towards
I'm trying to manipulate an avatar, so it points with its hand towards different points ( for example having the avatar point at the viewpoint consistently throughout the script ). I tried to duplicate the code in the follow-that-gaze tutorial, but with different bones (shoulders, arms...), but didn't get any sensible graphic result. Could you please help? Just to clarify - i simple want the whole arm to point at a given direction.... thanks! dan. |
I created a simple BonePointer class that allows you to specify a bone and where to point it at. This example will create an avatar and have it point its right arm towards the viewpoint. Let me know if anything is unclear.
import viz viz.go() class BonePointer(object): """Class for pointing a bone at a specified point""" def __init__(self,bone,offset=None): self._node = viz.addGroup() self._node.visible(0) self._bone = bone #Get offset matrix to child bone if offset is None: srcPos = bone.getPosition(viz.AVATAR_LOCAL) dstPos = bone.getChildren()[0].getPosition(viz.AVATAR_LOCAL) self._node.setPosition(srcPos) self._node.lookat(dstPos) self._offset = viz.Matrix.quat(self._node.getQuat()) else: self._offset = viz.Matrix(offset) self._offset.invert() def pointAt(self,pos): """Point the bone at the specified position""" srcPos = self._bone.getPosition(viz.AVATAR_WORLD) self._node.setPosition(srcPos) self._node.lookat(pos) m = viz.Matrix.quat(self._node.getQuat()) m.preMult(self._offset) self._bone.setQuat(m.getQuat(),viz.AVATAR_WORLD) #Add avatar model = viz.add('vcc_female.cfg',euler=(180,0,0)) #Create pointer object for shoulder bone pointer = BonePointer(model.getBone('Bip01 R UpperArm')) #Setup timer to update pointer every frame def UpdatePointer(): pointer.pointAt(viz.MainView.getPosition()) vizact.ontimer(0,UpdatePointer) |
Thank you for this class!
I'm wondering how can I use <vizact>.boneSpinTo() to have the avatar point at a certain position? I would like to make an animation sequence of pointing to an object and going back to it's neutral pose again. Can someone help me with this? Thank you. |
I found that the boneSpinTo function has an option that allows to put in a position vector.
However this doesn't result in correct behaviour. It seems to point at a random direction. I tried playing around with the different modes, with no succes. Code:
import viz viz.go() point = vizact.boneSpinTo('Bip01 R UpperArm',mode=viz.AVATAR_WORLD,point=viz.MainView.getPosition(),speed=90) #Add avatar model = viz.add('vcc_female.cfg',euler=(180,0,0)) def mykeyboard(key): if key == " " : model.runAction(point) viz.callback(viz.KEYBOARD_EVENT,mykeyboard) How can I make my avatar point at a certain location and when done go back to it's original position? Thank you! |
I tried putting a position point in the bonespinto function. This gives strange results. For example when I move the mainview to a position from where the avatar is visible and press spacebar the arm moves but not the the correct position.
Also after pressing spacebar a second time without moving the mainview the arm moves. Why is this, this shouldn't happen right? Code:
import viz viz.go() point = vizact.boneSpinTo('Bip01 R UpperArm',mode=viz.AVATAR_WORLD,point=viz.MainView.getPosition(),speed=90) #Add avatar model = viz.add('vcc_female.cfg',euler=(180,0,0)) def mykeyboard(key): if key == " " : model.runAction(point) viz.callback(viz.KEYBOARD_EVENT,mykeyboard) Can someone help me with this? Thank you! |
I think the issue maybe that the center of the bone spins to the correct location but the bone center is not necessarily facing the same direction as the end of the bone, which is what you want in this case. It maybe necessary to calculate an offset for the spinto point or orientation. I'll check with a developer for suggestions.
Thank you. Looking forward to your reply.
Hi Jeff,
is there any news on the boneSpinTo a position problem? Thank you. Best, Jeroen Derks |
Thread Tools | |
Display Modes | Rate This Thread |
Similar Threads | ||||
Collision of an avatar with a quad | Frank Verberne | Vizard | 8 | 06-04-2008 09:44 AM |
Looking through the eyes of an avatar | Frank Verberne | Vizard | 2 | 04-01-2008 05:52 AM |
making a talking and imitating avatar | marc van gaal | Vizard | 9 | 10-20-2006 04:28 AM |
Generating morphs when making new avatar heads.. | vjmcho | Vizard | 1 | 09-18-2006 02:36 PM |
Making an avatar speak while performing an idling animation | vr_boyko | Vizard | 1 | 10-05-2004 04:23 PM |
