Old 01-26-2017, 03:17 PM
Canucks Canucks is offline
objects in a scene..how to do this
im using the lab.osgb as my main scene. I put obstacle such as crate.osgb. When participant using marker try to walk he pass through the object. How can I make it that if the participant doesn't lift his leg high enough it get stuck behind the object?
Old 01-27-2017, 09:35 AM
I used collide plane but still does it
Old 02-01-2017, 02:27 PM
There's not a built-in function to do this. You could try using a proximity sensor to detect when the user is near the crate. Then get the position of the foot tracker and check to see if it's above the height of the crate. If not, prevent further updates to the viewpoint position.
Old 02-14-2017, 11:47 AM
Hi Jeff,
How do you compare just Y values?
Let's say getPosition () returned (1,1,2) and box's dimension is ( 2,2,2) so Y value is smaller..how do you compare just y values?
Old 02-15-2017, 05:25 PM
The getPosition() command returns an [x,y,z] list that you access like other Python lists:
pos = tracker.getPosition()
x = pos[0]
y = pos[1]
z = pos[2]
scene, texture, vizard
Changing objects in scene Van Vizard 2 12-02-2016 02:04 AM
How to show different objects on different windows from the same scene Joran Vizard 3 07-14-2014 03:07 PM
Copying Scene? Brett Lindberg Vizard 0 08-28-2009 11:56 PM
importing a single WRL with many objects. giancamati Vizard 3 12-18-2006 01:13 PM
