Old 02-07-2013, 08:48 AM
jfenster jfenster is offline
"Could not find plugin to read objects" error?
Hey guys,
I have a problem where I am trying to load a character into Vizard 4.0, but whenever I try my character is extremely distorted as you can see by the image
I get the error message Warning: Could not find plugin to read objects from file "<none>".
It appears 4 times.
Any idea what the error could be?
Old 02-14-2013, 08:46 AM
Does anybody Know the issue?
I was able to fix the textures but the mesh still comes out wonky.
Old 02-17-2013, 11:41 PM
sleiN13 sleiN13 is offline
It might be that your skeleton or animation uses a different coordinate system (different Up axis).
Old 02-27-2013, 11:35 AM
Hi Jfenster,
You may be doing something wrong in your export process. Your screenshot looks similar to what tends to happen when a mesh is loaded onto an incorrect skeleton. You may also have a typo somewhere in your CFG.
Can I get a look at your Max file and exported avatar? You can upload a zip of them here:
http://www.worldviz.com/support/upload
Error: Could not find plugin to read objects from file jde Vizard 3 02-15-2012 01:49 PM
Error loading plugin djdesmangles Vizard 2 10-02-2008 07:13 AM
