Old 03-30-2011, 06:18 PM
Zhi Zhi is offline
3D grass shader to mimic large grass field
Hi all,
I am new to Vizard. I used Virtools previously. There are some sample compositions in the Virtools forum, using shader to create mimic grass field effect. Some 3d model software, such as the 3ds max, also support online rendering of grass/fur effect. I am curious whether anyone has used shader in Vizard to mimic large field of grass land. Is there any link or script that we can share on this topic?
Thank you.
Zhi
Old 04-02-2011, 01:55 PM
Zhi Zhi is offline
Never mind. I found a way to use 2D texture to create a wonderul large grass land effect.
Close the thread.
Zhi
Old 04-13-2011, 12:56 AM
JvdBosch JvdBosch is offline
Please share this with the rest of us. Did you use the shell technique?
Old 04-13-2011, 10:21 AM
Zhi Zhi is offline
I do not use any shell technique. I simply found a very nice seamless grass texture (as attached) and applied it to the ground. To get rid of the regular pattern due to the repeated tiling of the grass patch (which gives a strong linear perspective cue). I 'blend' the detailed grass ground with a huge noise texture surface. The visual effect of such a grass field looks pretty good, even though it is still 2D textured. Here is the code:
grass = viz.addTexture('Grass.jpg') #Create the detailed grassland with about 100 m in diameter
for x in range(-51, 52, 2):
for z in range(-51, 52, 2):
if (x*x + z*z) < 52*52:
ground = viz.addTexQuad()
ground.setScale([2,2,1])
ground.setPosition([x, 0, z])
ground.setEuler([0, 90, 0])
ground.texture(grass) # Wrap texture on quad
BK = viz.addTexture('Noise.jpg') #Blend the detailed grassland with a low frequency noise map 100 m x 100 m
BKGrnd = viz.addTexQuad()
BKGrnd.setScale([100,100,1])
BKGrnd.setPosition([0, 0, 0])
BKGrnd.setEuler([0, 90, 0])
BKGrnd.texture(BK)
BKGrnd.zoffset(-1)
BKGrnd.alpha(0.2)
ID:	416   Click image for larger version
Old 04-14-2011, 05:05 AM
You can also put the same texture in another map channel and repeat it on a larger scale, possible even rotated.
                    tex = node.getTexture(unit=0)
                    node.texture(tex,unit=1)
                    node.texblend(0.2,unit=1)
                    trans = viz.Transform()
                    trans.setScale([0.2,0.2,0.2])
                    trans.setAxisAngle(vizmat.EulerToAxisAngle(0,0,45))
                    node.texmat(trans,unit=1)
Old 04-14-2011, 10:35 AM
Zhi Zhi is offline
Hi JvdBosch,
What does the trans.setScale([0.2,0.2,0.2]) do. Does it rescale the node or the texture map?
In my code, I have more than 2000 small ground patches (2m x 2m) with the same texture. I have another huge ground patch (100m x 100m) which has a different texture. My question is whether I can blend the two textures as if they were applied to the same node (i.e. the 100m x 100m patch), using the texblend function you suggest?
Old 04-18-2011, 06:38 AM
The setScale indeed rescales the copy of the texture, to be re-applied to the node and blended with the original texture.
I don't get your second question... Could you clarify it?
Old 04-18-2011, 09:03 AM
Zhi Zhi is offline
My understanding of the node.texblend() method is that it blends the two texture layers of the same entity. In my case, it is the ground. If the ground is only a single entity, this might work. However, the grass texture I have only matches 2 m x 2 m area (if you apply it to a larger area, it looks not real). To have a larger area of grass field, I have to repeat the ground patch (in my case, more than 2000 repeats). Although the texture itself is seamless (it is amazingly made), it contains both high spatial frequency and low spatial frequency components. The high spatial frequency component will make the repeated ground contain noticeable linear perspective cue. It is trivial for most VR applications, such as games. But, it is not good for some spatial perception experiments, because the real grass field do not have such a strong linear perspective cue. The trick I used here is to superimpose a huge texture (the 100m x 100m patch), which only contains low frequency component. This will substantially reduce the noticeable linear perspective cure. See the attached screen shots for comparison. To do this, I used the node.alpha() method. My question is whether the node.texblend() method can accomplish it as well.
ID:	418   Click image for larger version
Name:	less linear perspective.JPG
Old 04-21-2011, 07:34 AM
What happens if you use my code on your grass node, without superimposing this other texture?
Another option is a blend-shader which blends according to the distance to the viewpoint, to keep close sharpness.
Old 04-22-2011, 02:43 PM
Zhi Zhi is offline
Seems not help with your code (see attached screen shot). I assumed the "node" in your code is the "ground" in my code.
How to make a nice grass field? Xianshi Xie Vizard 1 07-01-2009 12:26 PM
Multiple Textures for Diffuse and Specularity Shader Issue shivanangel Vizard 1 05-11-2009 10:44 AM
