Old 01-10-2011, 03:39 PM
blessonisaac blessonisaac is offline
Intersense wand and Head tracker
Hello tech. support,
I am using mechdyne PowerWall for VR modelling. I am using intersense wand and shutter glass as position tracker and head trackers.
1. How do i activate both simulatneously?
I could activate only one tracker at a time. Please see the codes below. I can enable each tracker by switching from T to S and vice versa in the line: link=viz.link(T,view)
viz.go(viz.QUAD_BUFFER)
viz.clearcolor(viz.BLUE)
view.setPosition(0,0,-10)
# activating head tracker
PORT_INTERSENSE = 1
sensor1 = viz.add('intersense.dls')
#activating wand
PORT_INTERSENSE = 2
sensor2 = viz.add('intersense.dls')
S = sensor1
T = sensor2
link = viz.link( T,view)
2. When the intersenses are enabled, the scene is rotated 90 degrees from its yaw . It should be [0,0,0] in the beginning. Why is this happening?
3. How do I call a function using sensor buttons?
for example,
def moveforward(view):
move=vizact.move(0,0,-1,1)
view.addAction(move)
vizact.onkeydown('e',moveforward,view)
# This function will move the scene 1 unit forward on keydown 'e'
If I want to use wand to call for the same function, the following codes must be used.
vizact.onsensordown(sensor,button,function,argumen ts)
I am using IS 900 intersense. what is the parameter i have to provide at sensor? For button, what do i give for button?There are four buttons and a toggle key for wand
Please reply,
Blesson Isaac
Research Assistant
Mechanical Enginerring
Prairie View A&M University
Cell # 713 553 4037
