Old 10-27-2010, 08:08 PM
7up 7up is offline
collide
Hello all.
I ‘d like to use collide by vizard.
For study, when adding and moving avatar in physics2.py of help, a problem occurred.
If avatar collides while the box is moving, it will react, but when the box has stopped, avatar will pass through a box.
While a ball is crashed, avatar doesn't strike. It is why?
Thanks for your help.
#Declare some constants
GRID_WIDTH      = 6
GRID_HEIGHT     = 6
SPACING         = 1.05
MAX_BALLS       = 20
MIN_POWER       = 1
MAX_POWER       = 80
import vizmat
import vizinfo
vizinfo.add('Hold down left mouse button to charge up\nRelease left button to fire ball\nPress \'r\' to reset boxes')
#We need to enable physics
viz.phys.enable()
#Add a ground with an infinite collision plane
ground.collidePlane()
#List for holding the boxes and balls
boxes = []
balls = []
for i in range(GRID_WIDTH):
    boxes.append([])
    for j in range(GRID_HEIGHT):
        #Add a box model
        box = viz.add('box.wrl',cache=viz.CACHE_CLONE)
        #Use the boxes bounding box for collisions
        box.collideBox()
        #Add the box to the list
        boxes[i].append(box)
for x in range(MAX_BALLS):
    #Add a ball model
    ball = viz.add('ball.wrl',scale=(2,2,2),cache=viz.CACHE_CLONE)
    #The balls collision will be represented by the bounding sphere of the ball
    ball.collideSphere()
    #Add the body to the list
    balls.append(ball)
#Create a generator this will loop through the balls
nextBall = viz.cycle(balls)
#Add a green marker that will show where we are aiming, disable picking on it
marker = viz.add('white_ball.wrl',color=viz.GREEN)
marker.visible(viz.OFF)
marker.disable(viz.PICKING)
#Add a progress bar to the screen that will show how much power is charged up
power = viz.addProgressBar('Power',pos=(0.8,0.1,0))
power.disable()
power.set(0)
#Move the head position back and up and look at the origin
viz.MainView.setPosition([0,5,-20])
viz.MainView.lookat([0,0,0])
#Disable mouse navigation
viz.mouse(viz.OFF)
#This function will reset all the boxes and balls
def ResetObjects():
            #Reset the physics of the object (This will zero its velocities and forces)
            boxes[i][j].reset()
            #Reset the position of the box
            boxes[i][j].setPosition((i*SPACING)-(GRID_WIDTH/2.0),j*SPACING+0.5,0)
            #Reset the rotation of the box
            boxes[i][j].setEuler([0,0,0])
    for b in balls:
        #Translate the ball underneath the ground
        b.setPosition([0,-5,0])
        #Disable physics on the ball
        b.disable(viz.PHYSICS)
ResetObjects()
#'r' key resets simulation
vizact.onkeydown('r',ResetObjects)
def ChargePower():
    #Get detailed information about where the mouse is pointed
    info = viz.pick(1)
    #Show and place marker based on intersection result
    marker.visible(info.valid)
    marker.setPosition(info.point)
    #Increment the amount of power charged up
    power.set(power.get()+0.05)
vizact.whilemousedown(viz.MOUSEBUTTON_LEFT,ChargePower)
def ShootBall():
    #Hide marker
    #Convert the current mouse position from screen coordinates to world coordinates
    line = viz.MainWindow.screenToWorld(viz.mouse.getPosition())
    #Create a vector that points along the line the mouse is at
    vector = viz.Vector(line.dir)
    #Set length of vector based on the amount of power charged up
    vector.setLength(vizmat.Interpolate(MIN_POWER,MAX_POWER,power.get()))
    #Move the next ball to be fired to the begin point
    b = nextBall.next()
    b.setPosition(line.begin)
    #Reset the ball, set its velocity vector, and enable it
    b.reset()
    b.setVelocity(vector)
    b.enable(viz.PHYSICS)
    #Reset the power
    power.set(0)
vizact.onmouseup(viz.MOUSEBUTTON_LEFT,ShootBall)
#Set the background color
viz.clearcolor(viz.SKYBLUE)
#add avatar
avatar = viz.add('vcc_male.cfg',pos = [0,0,5], euler = [180,0,0])
avatar.collideMesh()
avatar.disable(viz.DYNAMICS)
avatar.state(2)
import math
import time
def run_around():
	newX = -math.cos(time.clock()) * 1.9
	newZ = math.sin(time.clock()) * 1.9
	avatar.setPosition([newX, 0, newZ], viz.ABS_PARENT )
	avatar.setEuler( [time.clock()/math.pi*180,0,0], viz.ABS_PARENT )
vizact.ontimer(.01, run_around )
Old 10-29-2010, 11:02 AM
You could try using a collideBox shape on the avatar instead and removing the following line:
Old 10-31-2010, 06:35 PM
7up 7up is offline
Thanks very helpfull!
Collision problem Dave Vizard 2 09-16-2010 04:25 AM
Collide mesh on child objects Enlil Vizard 1 08-31-2010 05:52 PM
Collide Surface Problem Boerske Vizard 0 10-05-2009 12:14 PM
Physics Problem Sandro Holzer Vizard 4 03-29-2009 10:51 PM
Registering 2 objects to show the collide djones1010 Vizard 1 03-25-2009 12:35 PM
