Avatar animation -- change states
I want to change my avatar's states according to conditions. However, there are some problems with the codes: Code:
def ani_change(): female1 = viz.add('Avatars/Avatars/CC2_f001_hipoly_A1_v2.cfg') female1.setPosition(1,0.5,1) female1.setEuler(90,8,0) bloNo = 10 Code = [0,1,0,1,0,1,0,1,0,1] for block in range(bloNo): female1.visible(viz.ON) if Code[block] == 0: female1.execute(8,0,0,freeze = True) female1.setAnimationSpeed(8,0) elif Code[block] == 1: female1.execute(3,0,0, freeze = False) yield viztask.waitTime(3) for j in range(10): female1.blend(3,1-float(j/10)) female1.blend(8,float(j/10)) yield viztask.waitTime(float(j/2)) yield viztask.waitTime(0.5) female1.state(8) female1.visible(viz.OFF) yield viztask.waitTime(5) viztask.schedule(ani_change()) 1) The avatar's states don't change; 2) The amplitude of the avatar's movement decrease across different trials. Eg. The highest point that her arm could reach is always lower than in the previous trial. Many thanks! |
Tags |
aavatar, animation |
Similar Threads | ||||
Walking Animation of Avatar | pradeep | Vizard | 1 | 07-03-2014 03:35 AM |
Clarification on CAL3D Avatar Animation in Vizard | shivanangel | Vizard | 2 | 11-22-2010 07:16 AM |
Collision and avatar animation | shahramy | Vizard | 2 | 10-26-2010 11:47 PM |
changing between avatar states | dan12345 | Vizard | 1 | 06-23-2008 01:39 PM |
avatar animation problems | jrodman | Vizard | 1 | 01-18-2006 09:12 AM |
