Old 03-30-2017, 06:25 PM
CARISMA CARISMA is offline
Rookie: Skeleton animation comes uncoupled when exporting to osgb
Hello everyone, I apologize in advance if this is pathetically simple. This is the first experiment I've tried running in Vizard, so I'm a gross rookie.
I've used motion capture (Motive) to create an animation and paired it with an avatar (via Autodesk). In 3ds Max everything is working just fine: the character mesh moves along with the skeleton, no issues. However, when I export the .osgb and then call it in Vizard, the mesh appears as normal, but only the skeleton is animated. It rather alarmingly pulls through the avatar's mesh and does the animation routine on its own. Distressing.
I can't figure out what I'm doing wrong on my export that causes the skeleton to no longer be rigged to the mesh. I would deeply appreciate the help.
Thank you!
3ds max 2014 crashing on exporting to OSGB raj Vizard 1 09-16-2015 03:13 PM
Trouble Exporting OSGB Animations via Sequence Helper (3Ds Max) envi253 Vizard 1 06-05-2015 11:31 AM
Weird colors exporting OSGB from 3DS nkinerd Vizard 2 05-09-2013 03:53 PM
Exporting cal3d animation creates too many keyframes tgoulart Vizard 2 03-18-2013 04:36 PM
Clarification on CAL3D Avatar Animation in Vizard shivanangel Vizard 2 11-22-2010 07:16 AM
