Old 08-14-2020, 05:08 AM
jericson jericson is offline
Registered User
Using viz.window.screenCapture in a loop?
Hello, I'm having trouble using viz.window.screenCapture() to grab images before and after a list of objects have been removed from a scene. This short example is analogous to what I'm trying to do:
def showDebugBall(x,y,z,size=1):
	ball = viz.add('ball.wrl')
	ball.setQuat(0,0,0,1)
	ball.setPosition(x,y,z)
	ball.setScale(size,size,size)
	smallball = viz.add('ball.wrl')
	smallball.setQuat(0,0,0,1)
	smallball.setParent(ball)
	smallball.setPosition(x,y,z)
	smallball.setScale(0.5*size,0.5*size,0.5*size)
	return ball
objects = []
n = 12
for i in range(n):
	aball = showDebugBall(0,2,i)
	objects.append(aball)
viz.window.screenCapture("images/Before.png")
for obj in objects:
	obj.remove()
viz.window.screenCapture("images/After.png")
If I run this code as is, the Before and After images show only a ground and sky plane, but no objects.
If I comment out the loop that removes the objs and also comment out the "After.png" screenCapture line, I get a "Before.png" that includes the objects, as expected.
It looks like there's a note about viz.window.screenCapture in the documentation: "Note: The image is not generated immediately. Vizard must wait until the next frame is rendered before it can capture the image." But I'm not sure how to modify the code based on this info.
Old 08-14-2020, 06:57 AM
Here's an example using a task function that should capture an object before and after removing it:
import viztask
ball = viz.addChild('beachball.osgb', pos=[0,1.8,2])
def screenCaptureTask():
	viz.window.screenCapture('Before.png')
	yield viztask.waitFrame(1)
	ball.remove()
	viz.window.screenCapture('After.png')
viztask.schedule( screenCaptureTask() )
remove objects, saving, screen capture, screenshots, viz.window.screencapture
Calling vizard functions in a loop omidbrb Vizard 1 09-23-2009 09:19 AM
screenshots using a loop krimble Vizard 2 09-14-2009 02:20 AM
Creating a loop to switch between menu pages RodRSpv Vizard 1 03-02-2009 02:19 PM
For Loop in Callbacks? DrunkenBrit Vizard 2 02-19-2009 12:26 AM
for loop concatenation for 300 billboarding trees eugcc Vizard 4 04-22-2004 12:46 AM
