Old 05-21-2018, 08:48 PM
groot groot is offline
Registered User
Rotation of MainView by a certain angle without use of on.keydown
I have tried vizact.spin and vizact.spinTo for this, but they only move to fixed angles relative to the original viewpoint.
eg. below is the least buggy code:
HTML Code:
turnRight = vizact.spinTo(euler=[90,0,0], speed=50)
turnLeft = vizact.spinTo(euler=[-90,0,0], speed=50)
	if "left" in command:
		viz.MainView.add(turnLeft)
	elif "right" in command:
		viz.MainView.add(turnRight)
However, if I am initially facing North, "left" would turn the MainView to West. After that, the command "right" would turn MainView to the East, instead of what we want, North.
Could someone advise me on what to do? Thanks!
Old 05-29-2018, 11:13 AM
I'll check with a developer about this and get back to you.
Old 05-30-2018, 03:20 PM
Are you setting this up for a system with position tracking?
rotate, spin
Problems with linking Sensor to MainView escmo Vizard 2 06-25-2013 01:15 AM
Mainview can't go back to original point jacky Vizard 1 06-04-2013 04:22 AM
Custom Joystick Rotation mhead10 Vizard 9 11-26-2012 12:06 PM
Unable to perform 360 rotation using vizact.spinto vijaykiran Vizard 2 09-29-2009 08:39 AM
calculating angle differences tavaksai Vizard 4 08-23-2004 10:04 AM
