Old 05-08-2013, 12:21 PM
brunomartelli brunomartelli is offline
Animation
I have some mocap characters and i want to be able to jump to and play from a particular frame - how do i do that?
Old 05-10-2013, 12:46 PM
I'm not sure what you mean by mocap characters. If have a Cal3D avatar with a saved animationyou can use <node3d:avatar>.setAnimationTime to play it from different points in the animation cycle.
Old 05-13-2013, 08:08 AM
yes but how specifically do I set the animation frame? I have a motion captured character, exported from 3dsmax using the Cal3d exporter, it has 1 animation and
bill = viz.addAvatar('LandMan.cfg' )
bill.state(1)
bill.setAnimationTime(1,180)
doesn't do it or any other combo of numbers ...
thanks
Old 05-13-2013, 05:25 PM
If the animation is cycling and you want to change the animation time, pass in 0 for the animation number. Does that work for you?
avatar = viz.addAvatar('vcc_male2.cfg',pos=[0,0,5],euler=[180,0,0])
avatar.state(4)
vizact.onkeydown('1',avatar.setAnimationTime,0,5)
vizact.onkeydown('2',avatar.setAnimationTime,0,13)
animation, frame, mocap
control animation on ive or wrl files? Darkmax Vizard 8 07-17-2012 12:13 PM
Clarification on CAL3D Avatar Animation in Vizard shivanangel Vizard 2 11-22-2010 07:16 AM
Animation Tracks.... k_iwan Vizard 2 03-26-2007 05:52 PM
Jumpy animation Elizabeth S Vizard 1 11-08-2006 02:11 PM
avatar animation problems jrodman Vizard 1 01-18-2006 09:12 AM
