Old 06-30-2006, 02:22 PM
spacefarer spacefarer is offline
3d viewpoint movement
I just tried the script for R2.5 as shown below which was given by Farshid, but it doesn't work with R3. Could anyone tell what's wrong with it, please?
#Add a ground
viz.add('tut_ground.wrl')
#Get main viewpoint object
#Create a variable that will tell whether viewpoing is currently moving/turning
view.animating = 0
#Variable that holds current destination value
final = [0,0,0,0]
def rotateview(x,y,z,angle):
#Make sure view is not animating
if not view.animating:
#Compute rotation of turning body 90 degrees to right
xform = viz.Transform(view.get(viz.BODY_MAT))
xform.preRot(x,y,z,angle)
final[:] = xform.getRot()[:]
#Start animating viewpoint
view.spinmask(viz.BODY_ORI) #Spin the body orientation
view.spinto(final,2,viz.TIME) #Spin for 2 seconds
view.animating = 1
def onkeydown(key):
if key == viz.KEY_UP:
pos = view.get(viz.HEAD_POS)
trans = view.get(viz.BODY_LOOK)
#Round values to nearest integer
final[0] = int(round(pos[0] + trans[0]))
final[1] = int(round(pos[1] + trans[1]))
final[2] = int(round(pos[2] + trans[2]))
view.goto(final,1,viz.TIME)
view.animating = 1
elif key == '6': #yaw right
rotateview(0,1,0,90)
elif key == '4': #yaw left
rotateview(0,1,0,-90)
elif key == '8': #pitch up
rotateview(1,0,0,-90)
elif key == '2': #pitch down
rotateview(1,0,0,90)
elif key == '9': #roll right
rotateview(0,0,1,-90)
elif key == '7': #roll left
rotateview(0,0,1,90)
viz.callback(viz.KEYDOWN_EVENT,onkeydown)
def onstop(object, type):
if type == viz.MOVE:
#Viewpoint is done moving, translate it to the final value just to be sure
view.translate(final)
view.animating = 0
elif type == viz.SPIN:
#Viewpoint is done spinning, rotate it to the final value just to be sure
view.rotate(final,viz.BODY_ORI)
view.animating = 0
view.callback(viz.STOP_EVENT,onstop)
Old 07-03-2006, 01:46 PM
I think you found a bug. The spin actions don't do anything when applied to the view.
Paul Elliott
WorldViz LLC
Old 07-25-2006, 02:12 PM
SpaceBall
You may probably find that you have a similar error ("TypeError: spaceturn() takes exactly 2 argumemts (1 given)") when you use SpaceBall. I'd appreciate it if you could fix it. Thanks!
Old 07-25-2006, 02:29 PM
The spin actions work fine on viewpoints. The problem is that the STOP_EVENT has been modified in 3.0. Replace your onstop function with the following:
def onstop(e):
	if e.action == viz.MOVE:
		view.animating = 0
	elif e.action == viz.SPIN:
		view.animating = 0
The spaceball callbacks have also been modified. Here is an example script for 3.0 that uses the spaceball:
import vizspace
viz.add('gallery.ive')
viz.mouse(viz.OFF)
def spacemove(e):
	viz.MainView.move(viz.Vector(e.pos)*e.elapsed)
def spacerot(e):
	viz.MainView.rotate(1,0,0,e.ori[0]*e.elapsed,viz.HEAD_ORI,viz.RELATIVE_LOCAL)
	viz.MainView.rotate(0,1,0,e.ori[1]*e.elapsed,viz.HEAD_ORI,viz.RELATIVE_LOCAL)
	viz.MainView.rotate(0,0,1,e.ori[2]*e.elapsed,viz.HEAD_ORI,viz.RELATIVE_LOCAL)
def spacebuttondown(button):
	print 'Button',button,'pressed'
def spacebuttonup(button):
	print 'Button',button,'released'
viz.callback(vizspace.TRANSLATE_EVENT,spacemove)
viz.callback(vizspace.ROTATE_EVENT,spacerot)
viz.callback(vizspace.BUTTONDOWN_EVENT,spacebuttondown)
viz.callback(vizspace.BUTTONUP_EVENT,spacebuttonup)
Old 07-25-2006, 03:03 PM
Thanks! It seems it works fine.
But when I use both SpaceBall and eMagin's HMD, only translation of SpaceBall input is working...
Old 07-25-2006, 03:06 PM
Are you sure you haven't accidentally disabled rotations in the Spaceball Control Panel?
Old 07-25-2006, 03:21 PM
I guess so. I just add the following two lines to your script, and tested comment/uncomment them. When you uncomment them, the head tracker of the HMD works, but rotation of SpaceBall doesn't work. If you comment them, SpaceBall works in 6DOF.
visor = viz.add( 'eMagin.dls' )
viz.link( visor, viz.MainView )
Old 07-25-2006, 03:24 PM
The reason it doesn't work is because you are linking the emagin to the main view. So the rotations of the spaceball are being overridden by the rotations of the emagin.
Old 07-25-2006, 03:31 PM
Forgot to mention, if you want to use the spaceball together with the emagin, then replace viz.HEAD_ORI with viz.BODY_ORI in the spacerot function
Old 07-25-2006, 03:37 PM
That's the easiest solution! It works perfect!! Thanks a lot!!!
