Old 05-16-2017, 05:05 AM
PaulNA PaulNA is offline
Error with Vizconnect
I have just installed Vizard 5 free 64 bit on a new computer with Windows 10 pro, and when I lunch Vizconnect from the Tools for settings, I get the error in the picture: how can I fix it?
Thanks.
Paul
Old 05-16-2017, 08:33 AM
Try reinstalling Vizard and let us know if that fixes the error. You can run the Vizard installer again and you'll be prompted to uninstall what's currently there.
Old 05-17-2017, 02:47 AM
I've already tried it without results.
Old 05-18-2017, 07:26 AM
Do you also get an error if you run the following code on it's own?
import os
print os.environ["HOME"]
Old 05-23-2017, 04:24 AM
Thanks! I've solved renaming the user of the computer and so the path.
Now I have this problem with Oculus: in the headset I see the message that Oculus Rift dk2 is not supported on the oculus platform.
Winzip.exe is taking a while to load etc...
Where is the problem (I have Windows 10).
Thanks.
Old 05-23-2017, 09:54 PM
Was the Oculus connecting in the Oculus software before you renamed the path? In the Oculus software, even though you have a warning about the DK2, does the headset show as connected in the Settings > Devices page?
Old 05-24-2017, 02:06 AM
It looks for ever for USB and HDMI for the haedset (it's ok for the camera), and this situation was both first and after the rename; while in the Settings > Devices page everything is connected.
In any case I've reinstalled the Oculus software, but without new results.
Old 05-24-2017, 03:05 AM
Since the headset is connected under Settings > Devices, try running the oculusExample.py script in Vizard (File > Quick Open > type: oculusExample). Does that work for you?
Regarding changing &using multiple tools at same time through vizconnect rajnishv Vizard 7 09-08-2016 04:48 AM
Zspace display in Vizconnect JB_HP_Viz Vizard 5 06-05-2015 03:28 PM
Switching between input devices setup in vizconnect and not using vizconnect JB_HP_Viz Vizard 1 01-20-2015 05:19 AM
delete hand in vizconnect rvenegas Vizard 4 06-05-2014 10:17 PM
Vizconnect Save As Dialog Jeff Vizard 0 05-01-2014 09:45 AM
