Old 12-11-2016, 11:56 PM
Vaquero Vaquero is offline
draw outline on objects?
Hey! I saw that there's a highlighter tool, but it depends on the user picking items by sending a ray cast. I'd like to highlight objects that get chosen by my script (randomly from a list of items), not by the user.
Is there a way using the highlighter tool or do I have to create a shader effect?
Old 12-13-2016, 03:53 PM
Yes, the highlighter module has an outline object that you can add models to directly:
import viztask
viz.setOption('viz.display.stencil',1)
environment = viz.addChild('sky_day.osgb')
soccerball = viz.addChild('soccerball.osgb',pos=[-0.5,1.8,2])
basketball = viz.addChild('basketball.osgb',pos=[0,1.8,2])
volleyball = viz.addChild('volleyball.osgb',pos=[0.5,1.8,2])
items = [soccerball,basketball,volleyball]
from tools import highlighter
outline = highlighter.Outline()
def outlineTask():
	while True:
		for item in items:
			outline.add(item)
			yield viztask.waitKeyDown(' ')
			outline.remove(item)
viztask.schedule( outlineTask() )
Trouble picking text3d objects Salvar Vizard 4 12-01-2010 03:07 PM
Not drawing invisible objects sleiN13 Vizard 9 11-23-2010 09:27 AM
