Old 07-08-2015, 07:34 AM
mape2k mape2k is offline
Disable dekstop window when using the Oculus Dk2
when I use the Oculus DK2 (direct or extended mode), there is always a window showing on the desktop monitor. How can I disable that, so the VR is only displayed inside the HMD?
We are using our Oculus as the only monitor and this creates problems because the second window is also rendered inside the HMD, overlapping the other one.
I used your Oculus example to test.
Thanks!
Johannes
Old 07-10-2015, 09:16 AM
You can try hiding the window using the following code:
viz.setOption('viz.window.visible',0)
However, I'm not sure how useful that will be, since it might prevent Vizard from receiving keyboard/mouse input.
Multiple post-process effects with oculus rift lklab Vizard 2 03-13-2015 01:48 PM
Oculus DK1 and DK2 in Vizard 5 Jeff Vizard 3 10-02-2014 11:00 AM
Window always on top madeinjava Vizard 4 08-27-2013 02:10 PM
Unexpected Change of Window Size javadi Vizard 7 07-23-2013 02:56 PM
