Old 01-20-2015, 04:37 PM
Aric Aric is offline
Finding button info over VRPN
I am installing 3rd party software on a system that already has PPT and Vizard installed. I have gotten the head and wand position tracking connected over VRPN but I cannot obtain the status of the buttons. The buttons work in Vizard. What are the correct VRPN client settings to get the button info, or where can I find the VRPN server information for this?
Old 01-22-2015, 04:28 AM
On the VRPN client side, you need to specify the marker ID number assigned to the Wand in PPT, the PPT IP address or name, and port 8945. You must specify port 8945 since the Wand data is sent through a different port than the default VRPN port. For example, if the wand is marker ID '3' and the machine name is 'PPT_MACHINE' the following would be used in Vizard to get the data via VRPN:
joystick = vrpn.addAnalog('PPT_WAND3@PPT_MACHINE:8945')
button = vrpn.addButton('PPT_WAND3@PPT_MACHINE:8945')
Old 02-03-2015, 10:00 PM
Thanks, I was able to get it working with your help. I'm not sure why but the wand tracking was PPT0@PPT_MACHINE while the buttons are PPT_WAND3@PPT_MACHINE:8945
ppt, vrpn
Problem reading VRPN info from ZSpace davev Vizard 2 10-24-2012 12:45 PM
VRPN info sdiverdi Precision Position Tracker (PPT) 5 01-16-2011 12:00 PM
Create Button or Text Chrissy2009 Vizard 1 07-15-2009 05:34 PM
Turning info boxes on and off Karla Vizard 2 12-17-2007 03:13 PM
button problems cade_mccall Vizard 3 02-22-2007 09:48 AM
