Old 12-16-2014, 06:48 AM
johnallen johnallen is offline
load jpg/bmp image file into wirtual world
I want to load a jpg image file into my virtual world and display it on the wall (like a picture in a gallery) of my room (which is already loaded as an osgb file)
I thought this would be simple to do but couldn't find an example. In the end I came up with this which sort of works but I was wondering whether there is a better way to do it?
In particular, a way to link the jpg to the wall rather than having to tweak the position coordinates until its close enough that it looks right (rather than using the magic numbers as I've done so that it works for my room)
    room = viz.add( 'room.osgb')
    pic1 = viz.addTexture('mona.jpg')
    quad = viz.addTexQuad(parent=room)
    quad.setPosition([ 0,1.6,2.05 ])
    quad.texture(pic1)
John
Old 12-16-2014, 04:57 PM
You'll probably want to apply the texture to a sub-part of the model rather than the model as a whole. In the following code a new texture is applied to one of the gallery paintings:
gallery = viz.addChild('gallery.osgb')
texture = viz.addTexture('lake3.jpg')
gallery.texture(texture,node='painting_starry-night')
image jpg bmp
how to start video texture on world load in cave mode raj Vizard 3 02-27-2014 04:55 PM
ERROR: Failed to load .ive file turgutm Vizard 1 09-16-2010 05:16 AM
Failed to load wav file BrynJ Vizard 1 04-24-2008 09:35 AM
File Path 4 Object Load softscan2 Vizard 1 09-23-2005 08:59 AM
